noice under rear right wheel (under body)
Old Apr 17, 2008 | 04:01 PM
jairajvg's Avatar
Default RE: noice under rear right wheel (under body)
Thanks James, I will take it to a dealer and check it. But as per an earlier post (same thread) from captian is that there is a recall on fuel pums, when I did a research on recall, I found that only 2003 A4 has that fuel pump recall. What about mine (2002 A4 1.8T).
Again I appreciate your guidance so far...
Old Apr 17, 2008 | 04:03 PM
jamesfreeman86's Avatar
ORIGINAL: Audinick81
What kind of noise do you hear? Is it a ticking noise or buzzing noise or something else? I'm experiencing a ticking noise around the same place on my car as well... still I don't know what it is.
Ummm..... he said "squealing noise under the body close to the rear right wheel" ----I'd take a wild guess and say it was a SQUEALING NOISE!!!!
Post your problem with more explanation in another thread....
Old Apr 17, 2008 | 04:57 PM
jairajvg's Avatar
I am taking my car to a Audi repair shop in Maryland "Pro-Imports", I hope they can solve the problem without a big bill. I will update this post once I get to know about it.
Old Apr 20, 2008 | 12:27 PM
muckdawg24's Avatar
Hey jairajvg, I know this is a shot in the dark, but I had a squealing noise and it was a piece of metal jammed in between my brake pad and rotor.
Old Apr 23, 2008 | 04:33 PM
jairajvg's Avatar
Hi James,
As update to this thread:
The technician has confirmed that the sound is due to a problem in fuelpump. He is going to work on this today.
Old Apr 24, 2008 | 02:07 PM
SrK's Avatar
SrK
Before changing the fuel pump have your fuel filter replaced and try it out that way. I had the same problem turned out to be the fuel filter. It was clogged making the pump work harder and making a noise. But if it is still there after the filter change I would look into the fuel pump...
Old Apr 24, 2008 | 02:09 PM
captain's Avatar
Good idea SrKasone will want to change the filter anyway.
Old Apr 24, 2008 | 07:21 PM
  #18
deephouse's Avatar
I'm doing the fuel pump on my URS4 this weekend. how's this for disgusting. 191K original fuel pump.
PUKE.
Old Apr 25, 2008 | 09:37 AM
  #19
Hailjericho's Avatar
Member
Replace the fuel filter before you do anything else. The dealership will more than likely try to have you invest in a fuel pump to make more money; but the fuel filter should only cost you about $60 dollars vs. a 300-500 repair of the fuel pump. I had the same problem in my 2003 1.8t FWD and simply replaced the fuel filter myself and got rid of the problem immediately!
Old Apr 25, 2008 | 03:19 PM
  #20
jairajvg's Avatar
Here is the update, my car is at the workshop now, the mechanic says that it would could be a problem with the pump or the noice is due to some debries. The issue is: he says just to check if either of these two is the actual problem it would cost 3-4hrs labour. My extended warranty says they will cover fuel pump replacement and related labour but if it is just cleaning up debries then they won't cover anything, which means I would have to take care of the labour charges to cleanup the debries. If it is something very simple I would like to do it myself, but as the mechanic suggests it isa 3-4hr job, then... I don't know. Please suggest.
