oil in chambers
Old Aug 26, 2008 | 05:34 PM
guru_king423's Avatar
Member
Default oil in chambers
so i decided to change my air filter and spark plugs today.
everything went well with the air filter.
It went wrong when i found oil in my spark plug chambers.
anybody now what will happends if it continues to run this way
Member
will this prevent my car from turning on cause i was dealing with that issue.
Old Aug 27, 2008 | 05:51 PM
silveraudi98's Avatar
Sounds like an internal valve cover gasket leak. It's a fairly easy fix. Parts should only cost you about 30 bucks and depending on how mechanically inclined you are you can do ityourself. It could possibly effect starting if the oil was getting on the plugs.
Old Aug 27, 2008 | 06:24 PM
monkey323i's Avatar
Normal for 4 years+ cars to have Valve Gasket leak.
replaced valve gasket on my AVK-3.0 engine 6 monthes ago.
They found the oil leak when doing the spark-plug replacement.
total less than$300
Old Sep 21, 2008 | 09:26 PM
jhsteel82's Avatar
hm mine is starting weird...sometimes it will start on the first time other times it takes twice to start it and i did replace the plugs and noticed oil in the chambers as well but kinda shrugged it off...thought maybe that upon filling the engine w/ oil some spilled in there or somethin. Ive replaced everything that i can think of on this car and it still is starting bad. Haven't looked at this issue yet. Could that be the problem??
harwich07
Aug 12, 2009 09:14 AM
harwich07
Dealerships
Aug 12, 2009 09:09 AM
