only pulling 6 - 8 inches of vacuum
Old Mar 11, 2009 | 09:34 PM
salating's Avatar
Default only pulling 6 - 8 inches of vacuum
for some reason my car is only pulling between 6 - 8 inches of vacuum
i get a fluttering sound when i rev the car at idle
when i drive it, car runs fine boots stays up around 9psi and doesnt drop
not sure if i got a leak or a bad DV
any ideas on what to check other than all my lines
i am pretty new to these cars but seasoned as far as boosted applications go
thanks
Old Mar 12, 2009 | 02:48 PM
audiprotein's Avatar
possible boost leak...... bad dv...
does your car misfire?
Are u stock? cuz 7-9 psi is what u get if stock.
Old Mar 13, 2009 | 12:20 AM
salating's Avatar
my car is stock
car does not misfire
runs really good actually, just pulls very little vacuum, it used to pull about 22 inches of vacuum
the fluttering sounds like the dv but would that cause my vacuum reading to be low depending on where the gauge is tapped into the system at?
i have yet to hook the vag-com up to it and see but with the fluttering something is definetly not right
Old Mar 13, 2009 | 12:49 AM
shane.trammell's Avatar
what exactly is an inch of vacuum? i was thinking psi, but 22 psi is a lot
Old Mar 13, 2009 | 11:39 AM
Myst420's Avatar
Boost is measured in pounds and vacuum is measured in inches. Normal vacuum is around 20 inches.
barney12
Apr 9, 2012 10:10 AM
Skythe
Jun 6, 2011 01:42 PM
Za4
May 27, 2008 10:56 PM
NeedMoreSpeed
May 26, 2006 05:06 AM
JDCrowe
Feb 14, 2006 05:20 AM
