which order should i get these done in?
Old Aug 14, 2008 | 02:05 AM
thedon28's Avatar
Default which order should i get these done in?
from most urgent to least..and if you know the cost too
1) trans. tail leak
2) oil leak causing cam tensioner problem
3) coolant leak
Old Aug 14, 2008 | 09:22 PM
euro_2nr's Avatar
Well I've never seen so many leak problems on a A4 before. Coolant would be the easiest I suppose. Just buy a new reservoir. They can't be too expensive. I believe ours are similar to the Passat so maybe it'll be cheaper but if you got the money then repair them all. How bad is the tranny leaking? Seal smoked?
Old Aug 14, 2008 | 10:17 PM
thedon28's Avatar
no clue..i brought to get my timing belt checked for free at the dealer and they came up with a list with these 3 things
Old Aug 15, 2008 | 12:10 AM
audiprotein's Avatar
None of these sound good. Depending on what stage of the leaks you got you need to decide. They usually tell people if the leak is small/medium/huge. Have u had any problems?
Old Aug 15, 2008 | 12:10 PM
thedon28's Avatar
yea i got the p0011 code which was something with the camshaft positioning sensor and then they said that 1 oil leak was puttin the wrong amout of pressure on the tensioner due to the leak..or something like that
Old Aug 19, 2008 | 12:02 AM
muckdawg24's Avatar
Ask them what they think. My mechanic/advisor always tells me which I should do first and if the other things can wait.
Inferno451
Dec 16, 2013 05:40 PM
cr.724
B8 Models
Dec 26, 2009 04:12 AM
mattr7786
Feb 6, 2009 02:53 PM
__DyNaSTY_X_
Jun 5, 2006 12:34 AM
ReX
Apr 2, 2006 08:52 PM
