P0421
Old May 7, 2008 | 08:21 PM
snr1951's Avatar
Default P0421
I've read the forums about the O2 sensorsi was wondering if anyone can help me out with where to buy them and how many wires each one has i called a place and they ask me for that info thanks in advance
Old May 8, 2008 | 12:47 AM
auditech79's Avatar
Default RE: P0421
http://www.bentleypublishers.com/tec....dtc.table.htm
P0421 isn't on that chart. Are you sure it has anything to do with O2 sensors?
Your O2 sensors have 4 wires by the way, and you can get them at www.ecstuning.com or www.purems.com
Old May 8, 2008 | 12:42 PM
auditurbo381's Avatar
Default RE: P0421
Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0421 is an emissions code for sure. i assume your using OBD II.i have a smiliar one because of my test pipe.
quick fix is change your spark plugs.. on might be fouled. or if not your 02 sensors are damaged. the secondary most likely. reading the "supposedly" fresh minty air you cat spits out. if that is the case you got to think further about what damaged it in the first place..... maybethe cat? what your mileage? check engine i assume? rough idling?
02 sensors are availbale at ECS tuning.com as auditech said.
good luck
2003audiA4avant
Jul 10, 2012 04:00 PM
saintforlife
Oct 26, 2011 08:57 PM
the24thletter
Apr 16, 2011 02:08 PM
alex jb
May 20, 2010 11:26 AM
Madtown
Jan 14, 2009 09:00 PM
