P0492
Old Oct 11, 2009 | 02:53 PM
crwalker54's Avatar
Default P0492
Hi Folks,
My check engine light has come on and it gives a:
PO492:P0492 16876 Secondary Air Injection System Insufficient Flow Bank 2
I know this is probably a combi-valve (EGR) or vacuum hose issue
My question is which one is bank 2?
It a 03 A4 CAB 3.0
Old Oct 12, 2009 | 02:36 AM
Dan1969's Avatar
You are correct, but I don't know where the pump is located. Try checking the part number for the pump with your dealer or just go and pick their brains see if they know where it's at. Or someone else like MidniteOyl will come by and tell you...
Old Oct 12, 2009 | 10:10 AM
tdoyle's Avatar
Not sure which bank is bank 2. The pump is located right behind the passenger side fog light though. I agree the odds are good the pump is fine and you have a vacuum problem. Start hunting around and replace anything questionable.
Old Oct 12, 2009 | 12:26 PM
pa4ul's Avatar
thats a vac leak i believe
Old Oct 13, 2009 | 03:56 PM
crwalker54's Avatar
Default Found it
Thanks guys, I found it,
Bank 1 -> Drivers Side
Bank 2 -> Pass side
jinsojoo
Feb 11, 2014 10:30 PM
cwedholm1
Mar 24, 2010 09:05 PM
twinturbosixer
May 2, 2009 09:25 PM
tjolson19
Jul 22, 2007 12:11 PM
KS_S8
Jun 3, 2007 12:27 PM
