PCV Check Valve 06a129101 bad ? Code P0171 too.
Old Mar 27, 2009 | 10:09 PM
chawkinson's Avatar
Default PCV Check Valve 06a129101 bad ? Code P0171 too.
Hi Everyone,
My 2004 A4 (1.8T FWD) has been idling rough and I got code P0171 which means "running lean". When checking for a vacuum leak, I noticed that the pancake looking valve at the rear of the engine (p/n 06a129101c) is sucking around the top of it at idle. Is this normal? If I plug the "leak" with my finger, the engine stalls. Anyone have any idea at all? Thanks in advance.
Old Mar 27, 2009 | 10:52 PM
chawkinson's Avatar
A little more info ... the valve is item #15 on this .pdf
http://peteandmichelle.lunarpages.co...-2003-2005.pdf
Its called a Pressure Regulating Valve.
Old Mar 28, 2009 | 02:27 PM
auditech79's Avatar
It must be a hell of a leak to cause the engine to stall and cause a lean code. Generally the PCV valve doesn't cause any fault codes besides burning oil in the intake. If you replace the PCV valve make sure you replace all vacuum check valves while you are in there to keep yourself from further headaches. They kind of look like #25 in your link.
Then tend to crack and cause this condition also.
Old Mar 30, 2009 | 03:57 PM
chawkinson's Avatar
I answered my own question... replaced the Pancake/Puck valve with a new one from the dealer (p/n 06a-129-101-F), cleared the P0171 code, and now it runs like new again! No more codes and no more rough idling either. Awesome!
Old May 7, 2012 | 06:03 PM
crashtriple3's Avatar
I had the same problem except I was sent part # 06A 129 101 A and the valve i pulled off my car is the 06A 129 101 C.
Can i use the "A" on my car (2004 Audi A4 quarto) or is the actually functionality of the two A vs. C different. Spring rate? vacuum control? etc.
The only mechanical difference i can see is on the port coming out of the bottom, It is slightly smaller in diameter but i can make it fit perfectly with a reducer. Can i use it like this? I started the car and it idled perfect but i am afraid to drive it.
Old May 31, 2014 | 09:56 PM
tshafii01's Avatar
Default Same issue, same fix, STILL rough idle
So I had same issue with air leak around the valve, replaced it as well as the hose under it, and after clearing the check engine light, I STILL have a rough idle. Any ideas?
mazzman912
Dec 16, 2019 03:28 PM
AudiZD
Jul 6, 2013 01:14 PM
TRX450ER
Aug 17, 2012 03:01 PM
basementwaj
Dec 22, 2007 03:21 PM
jpez
Dec 19, 2005 05:16 AM
