please help
Old Feb 21, 2012 | 12:19 PM
B6A4Ohio's Avatar
Default please help
I have an 02 a4 and i jave had some trouble with the idle as well as overall performance while driving. The car seems like it bogs down at about 4 thousand rpms and then again while it idles too. I have replaced the valve cover gasket, fuel pump, fuel filter, had the exhaust redone and still the same bogged down car. Any ideas before i take it to a mechanic that will rape the money out of my pockets? Thanks for any help!
Old Feb 21, 2012 | 12:23 PM
M5S5's Avatar
Tech Certified
Is the check engine light on? If so what are the fault codes?
Old Feb 22, 2012 | 12:25 PM
Dozanti's Avatar
b6a4ohio, where in ohio are you?
Old Apr 15, 2012 | 09:24 AM
Travs44's Avatar
I have a similar problem..when I go to give it it gas it just falls on its face..no power... I had a misfire code so I replaced the fuel pump dv and all four plugs and coils... Still having same issues... I don't know about your car but I'm no longer reading any codes or check engine light but it's still running Terrible...hopefully we can possibly figure it out together
Old Apr 18, 2012 | 11:03 PM
ImTheDevil's Avatar
Do a search for Throttle Body Alignment and try it out. If its out of whack it'll cause all kinds of issues with driveability.
Old Apr 19, 2012 | 12:06 AM
milan2k12's Avatar
check for vacuum hose leaks and vacuum valve leaks too
