Please HELP! ABS + ESP Ligths on + Brake Ligth Flashing + Air Bag
Hi,
I bought an Audi A4 2003 1.8T a few weeks ago and at the time only the ESP had problems and one AirBag module problem (G180)
Recently a friend of mine tried to do the Steering Angle Sensor (G85) Calibration with his Vag-Com software on his PC thinking it might correct the ESP issue.
But now, I have the ESP Ligth On (Solid), the ABS Light On (Solid) and the Red Brake Light in flashing + the Airbag light still on (solid)
So he came back today to do a full rescan of the car, and we found that the car has the "01486 - System Function Test" Activated, so I tried many times to complete the Test procedure as stated is the ross-tech How-To, but it doesn't change anything.
I also have a problem with the Front Right brake which makes a grinding sound, so me and my neighboor dissembled the caliper and found that the pins where really thight, so we put some grease on them and reput the caliper on. We also found out that the brakes pads were "craked" (Can a cracked brake pads throws a flashing Red Brake Light??)
I also checked the battery voltage, it's 12.4v. Could it be a bad ground somewhere ?
The car is not chipped, it's the original ECU.
So here is the full scan logs of the car, I'd really appreciate you give me some hint on where to look first cause i'm a little lost and disapointed after this day
Code:
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0003
Coding: 0016751
Shop #: WSC 78901
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
Readiness: 0000 1000
Address 02: Auto Trans
Controller: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 0910
Coding: 0001002
Shop #: WSC 00999
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 003 - Mechanical Failure - Intermittent
Address 03: ABS Brakes
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
2 Faults Found:
01486 - System Function Test Activated
35-00 - -
01423 - Lateral Acceleration Sensor (G200)
27-00 - Implausible Signal
Address 08: Auto HVAC
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
5 Faults Found:
01809 - Actuating Motor for Temperature Flap: Left (V158)
41-10 - Blocked or No Voltage - Intermittent
01810 - Actuating Motor for Temperature Flap: Right (V159)
01171 - Temperature Sensor: Passenger Side Heated Seat (G60)
29-10 - Short to Ground - Intermittent
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
01206 - Signal for Duration of Ignition: OFF
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul KAN 0305
Coding: 00014
Shop #: WSC 63351
2 Faults Found:
01800 - Light Switch (E1)
27-10 - Implausible Signal - Intermittent
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags
Controller: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 63351
2 Faults Found:
01222 - Crash Sensor Side Airbag: Passenger Side (G180)
012 - Electrical Fault in Circuit - Intermittent
011 - Open Circuit
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
No fault code found.
Address 17: Instruments
Controller: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03300
Shop #: WSC 00068
WAULC68E83A165572 AUZ6Z0B0229391
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 46: Central Conv.
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
3 Faults Found:
01616 - Signal Wire to Interior Monitor
00955 - Key 1
35-10 - - - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00020
Shop #: WSC 63351
4 Faults Found:
01539 - Headlights Not Adjusted
35-00 - -
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-10 - Open or Short to B+ - Intermittent
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
00776 - Level Control System Sensor: Left Front (G78)
31-00 - Open or Short to Ground
Address 56: Radio
Controller: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 01001
Shop #: WSC 94842
1 Fault Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
here is a new scan of the car and I still have the ebrake flashing + ABS and ESP solid + 3 beeps at starts,
where sould I start ?
Code:
Address 01: Engine
Coding: 0016751
Shop #: WSC 78901
Coding: 0001002
Shop #: WSC 00999
Coding: 04277
Shop #: WSC 06435
3 Faults Found:
35-00 - -
01119 - Gear Recognition Signal
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
Coding: 00014
Shop #: WSC 63351
Skipping Address 15-Airbags
Coding: 00041
Shop #: WSC 63351
Coding: 03300
Shop #: WSC 00068
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 11788
Shop #: WSC 63351
1 Fault Found:
Coding: 00020
Shop #: WSC 63351
2 Faults Found:
35-00 - -
Address 56: Radio
Coding: 01001
Shop #: WSC 94842
1 Fault Found:
amickee
Oct 8, 2010 08:02 AM
Splbasshead
Feb 2, 2009 08:17 PM
