Po 411 help!!
Anybody know a easy way to check code Po 411 on my 2003 A4 ...I found cracked check valve replaced it light still on checked hoese ECT.. Looks Ok ..I read all the Potential Causes and looks like I need to be a Audi tech to find it..Runs good.. I trying not drive it to the man.... He drives a new lambo.( Wonder how he makes his money ?? off people like me..Help..and THANKS
P0411 is an indication of a MAF sensor (mass air flow). A common cause is the vacuum lines conneted to the MAF. A leak or worn vacuum line will throw a P0411. Check the lines going to the MAF (near the air filter). If the lines are good, then replacing the MAF should solve your problem.
