Problem!
Old Dec 14, 2013 | 06:57 PM
alejandro.cartagena1's Avatar
Default Problem!
this is the second time the back coolant house blows off because of the heat, do you guys know if there is a house made of a better and more resistant material to heat than the oem that is sell?
Old Dec 16, 2013 | 04:07 PM
MKE_Audi's Avatar
If you blowing hoses I would look at why you are getting so much pressure. OEM hoses should handle normal coolant system pressure. Also check your reservoir cap as that should be the weakest link and let off pressure before a hose blows.
Could be a bad head gasket that is letting exhaust gas into the coolant and it can't get to the reservoir before it blows the hose.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
