problems pleaseeeee help.!
Old Oct 12, 2011 | 12:57 AM
audi.a4.turbo's Avatar
Default problems pleaseeeee help.!
So I recently changed my Thermostat, installed 034 silicone lower breather-hose, Spark plugs, and check valves(only left one out cause it look good still).
I now have a CEL. I dont know the code.
Seems that the car doesn't really want to crank over.(it takes 3 times exactly, every time I do it on the 3rd try it cranks over.)when it does crank over it runs really well, switching through all gears, it runs good.
-I tried my fuel rail to see if it sprays out, it does. so its not fuel pump
-tested the battery at auto-zone, they said it was pretty much brand new. 100% charged. alternator should be good because its charging the battery.
When engine is on, it barely idles. by the meaning of that i mean idles from 900 to 950 pretty close to 1000 rpms. i can barely feel it.
Anybody got any suggestions? (besides CEL cause i cant do anything about it till i check what the code is)
help would be appreciated.
EDIThhhh i also tried jump starting the battery, and it started rite away. like normal. i check the battery terimals and they are making good contact.
can it be the starter?
Old Oct 12, 2011 | 05:14 PM
BesI's Avatar
Most of the people say when it does not crank is the engine speed sensor, but until you scan it you can guess on everything.
Old Oct 12, 2011 | 07:35 PM
tmic0723's Avatar
had a somewhat similar problem last week, ended up costing 350$ including parts/labor. was hard to crank over. i had a cel and it would die at stop lights. i also had the EPC light on. ended up being the crankshift sensor which i think is the same as the engine speed sensor
Old Oct 19, 2011 | 01:11 AM
yeah, it was actually the cam position sensor. i took it out to inspect it before ordering the part, and turns out one of the wires inside the sensor was ripped off. so no contact was being mad. i all did was connect it, reset the engine, and its been clear ever since. starts up great.
Old Oct 19, 2011 | 10:52 AM
evelluser's Avatar
if you can jump it right away and it starts, then its your battery. the cold cranking amps are wearing out and the battery needs to be replaced. I know you said autozone tested it, but it seems like they just checked the voltage and that's all they did. I had that problem before too, then eventually it wouldn't start at all without a jump. changed batteries and good as new. you can always get a new battery and try it. if it doesn't help, just return it
Smokin Tubes
Feb 5, 2012 10:11 AM
misseswinky
Aug 7, 2007 03:39 PM
kazamajin87
Dec 8, 2005 01:08 AM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
