Question about coolant flange leak
Old Feb 11, 2019 | 08:34 PM
MyFreeAudi's Avatar
Talking Really Good DIY With Pictures
From our good friends at ECS Tuning:
https://blog.ecstuning.com/2017/09/1...e-replacement/
Old Jan 4, 2020 | 05:01 PM
Robert C's Avatar
Default Coolant flange leak (01 VW 1.8t)
Hey guys I wanted to share.
My coolant flange had an invisible crack in it.
The thing is 10 dollars.
​​​​​Don't reuse the old one.
Old Apr 2, 2020 | 05:05 AM
marteA4's Avatar
I replaced mine 2003 A4B6 2.0 its a easy job.
I had to replace the ( electric ) thermostat ( inc housing # 06B 121 111D ) and that rear flange at the same time. ( # 06B 121 133 )
It cracks its support ring inside & the 'O' ring moves & leaks ( which might be why its not leaking under pressure, as it will get pushed outwards & reseal again )
i also had to replace a coolant hose part ( # 06B 121 058 ) because one end had went really soft & its less than 1/2 the cost of the coolant it would loose if it burst.
So expect that if one of these parts need replacing, they all will. If i had the $$$ i would replace every hose as a kit.
You can buy that rear flange as a Aluminium version too. Ebay it.
I also replaced the Crankcase ventilation hose (# 06B 103 211 H ) $5 ebay China ( just cut its neck off to remove it easyier ) and the top housing it connects to ($30 VAG ) i used rubber tubing to connect that to the intake ducting ( too many $$ to buy a new one ) and a 1 way valve close to that.
Check all this stuff at the same time.
A couple of months later, two door mechanisms broke, easy fixes, cheap from China.
What I mean is, is that all of the same parts will break at near to the same time, so double check everything & buy the bits before they need replacing. I sound insulate the doors while i fix the window regulators ( winders mechanism ) & look at replacing the speakers too.
Old Jan 18, 2025 | 12:51 PM
PercivalShortz's Avatar
Is it on the passenger side leaking on the exhaust then it is likely coolant flange or hoses connected to flange.
phatjames167
Jan 4, 2014 07:42 PM
Pbcrazy
Feb 6, 2013 07:27 AM
brady3193
Oct 19, 2012 05:07 PM
bbeach
Oct 15, 2012 04:26 PM
jfact7
Oct 15, 2008 10:52 PM
