Oil light
Old May 25, 2020 | 04:24 AM
antonye's Avatar
Default Oil light
Audi B6 3.0ltr convertible. Oil light has started coming on flashing and beeping, then goes off, then a while later ion does the same. Its got plenty of oil in it and going to do an oil change asap.
any thought?
Old May 30, 2020 | 08:28 AM
Andrew Davies's Avatar
got same car and engine and had both errors
Is it oil level or oil pressure ?
if it is the oil level light it will be the sensor, its at the front of the car underneath you can get a replacement for less than $10 from China.
If its oil pressure light it could be the sensor (next to filter) or it could be your filter is getting clogged (that is what caused mine)
Old May 30, 2020 | 02:04 PM
antonye's Avatar
its a big symbol of an oil can flashing up
Old May 31, 2020 | 01:47 AM
If its yellow its your level sensor
if its red its either oil filter or pressure sensor
Old May 31, 2020 | 02:25 AM
antonye's Avatar
cheers Andrew
Old Jan 19, 2025 | 12:57 PM
PercivalShortz's Avatar
Liamox
Aug 25, 2015 04:07 PM
AWDrifter
Apr 6, 2009 01:40 AM
Rochelle_2010
Dec 1, 2008 02:04 PM
TexasAudi
Sep 16, 2005 09:13 AM
nanjil
Dec 26, 2004 01:59 AM
