Race Valve N75
Old Dec 19, 2013 | 08:13 AM
Coors's Avatar
Default Race Valve N75
Just picked up an '04 Ultrasport the other day and already made an appointment w/ AWE Tuning to take advantage of their "Winter Promotion": GIAC 93oct flash. To prepare for the flash I ordered a 710N DV and ECS Race N75 valve. I also have VAG-Com to monitor boost pressures.
I've read alot of reviews on the valve, seems like DBC cars go limp due to overboost and 50/50 DBW cars have zero issues. My question is, anyone running the ECS race valve or equivalent (N75 J or H) w/ GIAC (on a DBW) and have overboosting / limp mode issues?
Anyone running the valve w/ GIAC (on a DBW) and love it?
Old Dec 19, 2013 | 08:31 AM
Coors's Avatar
Reading a little further into this, found this reference which makes alot of sense.
Originally Posted by Jeff
A stock C valve at full duty cycle will make the same amount of peak/max boost as a J valve with full duty cycle...for your wastegate will be closed regardless. However, the J valve due to its slower response time and more restriction will cause the the boost to spike higher (for the reaction time to control is slower). Your car was optimized to run on the stock C valve (boost maps, fuel maps, injector on time), and like what 400HPA4 said...if GIAC wanted to run that extra boost/spike like you get in the J valve, it could have been an easy tweak on the original programming. The file is as agressive as it is already.
Also keep in mind that if your actual boost exceed your requested boost (Block 115), you will most likely go into limp mode with the throttle plate closing. Another thing to watch out for is with the added boost on your already "agressive" timing, you will most likely ping... and as a result will pull more timing (kill more power). You're better off running lower boost (keeps EGT's happy) with higher timing, than to run higher boost (extra heat) with retarded timing.
APRaudiA4
Feb 22, 2008 09:45 AM
xxipsxx
10
Mar 2, 2007 09:55 AM
a4modrcin
Mar 18, 2006 04:10 PM
Dunzie182
Feb 20, 2006 03:49 PM
trailboss
Nov 9, 2004 02:55 AM
