Replacing hydrolocked motor
Old Aug 23, 2010 | 11:50 PM
dmarek's Avatar
Default Replacing hydrolocked motor
I hydrolocked during a recent flash flood, so I am replacing my ruined 3.0 with 85,000 miles with a used motor with fewer miles. During the process, I thought I should have the shop install a new timing belt. Is it worth it to also replace the water pump? What else should I have the garage check or replace in the process?
Old Aug 27, 2010 | 10:45 AM
Mike-2ptzero's Avatar
You want to replace the water pump when replacing the timing belt, because if you have to replace the water pump later you will end up having to remove the timing belt.
Old Aug 27, 2010 | 05:05 PM
ppgoal's Avatar
Get a timing belt kit from Blauparts or ECS which includes waterpump, all the tensioners, new serpentine, thermostat, etc. Do it all at once as most of the cost is labor (~ 6 hours worth).
green2man0
Oct 3, 2014 09:28 AM
CTown
Oct 4, 2009 09:45 AM
driftking8732
Aug 26, 2009 06:54 PM
ivanmartinez
Dec 3, 2007 08:41 PM
mustang196718
Feb 12, 2007 08:48 PM
