rough idle & acceleration
Old Feb 23, 2009 | 04:37 PM
wolfdog's Avatar
Every automatic car I've had has vibrated more in gear than in park. If it's a huge difference then something might be up.
Check your snub mount.
Old Feb 23, 2009 | 05:20 PM
unoriginal's Avatar
Yes, but this vibration is like driving on those line things on the side of the highway that wake you up when you dose off and start veering off the rode.
Old Jan 26, 2012 | 10:18 AM
alfutbol12's Avatar
Unoriginal,
Did you ever find out what the problem was? I'm seeing the same symptoms.
Old Jan 26, 2012 | 12:34 PM
d21burggraf's Avatar
I'm curious also to see what the issue was.
Old Jan 26, 2012 | 02:11 PM
rowfour's Avatar
Is the RPM fluctuating? I.E. from cold start it will shoot to 2000 + then drop to 800 or so? If it does, vacuum leak. Possibly, the PCV valve below the intake manifold.
Could also be the flywheel if it vibrates.
browny355
Mar 25, 2011 11:49 PM
kkhakh
Nov 4, 2010 08:38 PM
kkhakh
Nov 3, 2010 02:54 PM
slew87
Aug 25, 2009 10:52 PM
Shakey
Nov 9, 2008 11:12 PM
