seafoam question
I used 2 cans: 1 in gas tank and 1/2 each in manifold and oil. I drove until gas tank was near empty and did the oil. I had no issues. The argument is leaving it in too long the stuff loosens up the sludge too much and it collects in the uptake screen. Don't leave it in long enough and it does nothing. You have to choose.
****, thats twice as expensive as what my job would be, also with the 1.8t you can see the belt right on the front of the engine, im thankful for that little bit at least
but with your engine, i dont believe you can see your belts, possible by taking the plastic cover off you will see them.
but dont take my word for it, ive never even looked at a 3.0 before.
At least on the 1.8, you can take off the timing belt cover. The black plastic engine cover "mates" with a piece in the very front of the engine. This piece covers teh timing belt. There are 2 or 3 metal clips you pop and you can pull it away to see the timing belt from the top.
on the 3.0 there's a torx screw that you need to take off to see the belt, you take the cover that says "3.0" and you'll see the torx screw there but, if the belt was done when recommended you won't be able to tell the difference. If you're not sure just do it. Find yourself a good shop and you can get it done for around 1500 bucks, much cheaper than repairing the engine due to a broken belt.
Ok. My question is if a i seafoam my car will it cause the timing belt to fail?
will i need new spark plugs after i feed it throught the brake booster line?
what kind of things should i expect (good and bad)?
I've heard good things about seafoam but i want to know how mush cash it will cost to have the end result of an smooth runing car and better gas mileage.
Put one can in fuel tank, then top it off with fuel. Once that fuel has been burned out of the tank you can proceed to step two. Suck 1/3 a can into a vacuum line (you can find detailed diagrams of which one online). Make sure to measure out 1/3 can and suck it up slowly. If you just plunge the vacuum line into the can you will suck in too much. Have someone ready to shut off the ignition as soon as all the Seafoam has been sucked in. They need to be ready to kill the engine by holding it in gear and letting out the clutch with the brakes on since the engine may diesel really bad. Wait at least 20 minutes before restarting the engine. Let it burn out, then take it for a romp around the block to blast the final puffs of smoke out. Now, if you are prepared to change the oil, pour half a can in the crankcase and let the engine idle for a few minutes - 10 or so. Drain oil. Replace filter and oil. Change spark plugs as they will be full of scale.
Your timing belt will not be affected by the Seafoam, but do replace it if you are concerned. A timing belt is so much cheaper than pulling the head and replacing the entire valve train.
How much cash will it cost? Just bought a can tonight for about $9.
We just bought a 3.0 Quatro, and I saw the bill for the past owner's timing belt failure at 72,000 miles. Almost $5,000. Change your timing belt already!
All this timing belt talk has got me worried. $1500 is not a small amount of money but niether is $5000!!!!
DO NOT FEED SEAFOAM THROUGH ANYTHING RELATED TO YOUR BRAKES!!! Only use seafoam in gas tank, oil, or the vacuum line going into the intake manifold. The techniques are documented in the many DIYs.
If done right, seafoam will help clean out deposits and to smooth idle, clean injectors, and reduce the chance of engine sludge.
I have no idea what you mean by your last question but seafoam is about $5 a can. If you don't like it, I think the other half of the crowd supports the Auto-RX treatment. I THINK, I don't quite remember the name.
