spacers what size???
Old 09-25-2008, 11:12 AM
pa4ul's Avatar
Default spacers what size???
What size do u think i should go with 12 15 or 20 mm spacers. Iam going to get them from ECS tunning is there a difference in the brands or are spacers spacers?
Old 09-25-2008, 02:06 PM
kwik_shift's Avatar
H & R spacers FTW!!!! It all depends on the rims you have that way the spacer's center hub will fit. If your going for spacers all around go 5mm thicker in the rear. I went 10mm all around the first time and it didn't look right. The front looked like they were sticking out a bit more than the rear. How wide are your rims?
Old 09-25-2008, 04:15 PM
audiprotein's Avatar
With stock 17rims, 15 in the rear, 10 in the front.
Old 09-26-2008, 03:27 PM
pa4ul's Avatar
i have 19's i was thinking of 15mm in the rear i want the rim to stick out just a tad.
Old 09-27-2008, 12:34 PM
Sublime865's Avatar
I'm thinking of doing spacers myself, but apparently I'd need to get new spacers when I jump to aftermarket rims due to bolt type? Or can I just get new bolts? I'd order at the same time just to make sure I had them...
Old 09-27-2008, 02:38 PM
pa4ul's Avatar
u have to get longer bolts. or u mean u have to get special spacers?
Old 09-29-2008, 10:36 AM
kwik_shift's Avatar
I have 8.5" wide wheels and runnin 20mm H&R's which gives you the stance you are looking for. It looks righteous, but if u ever carry passengers in the rear the tires will rub with the fender.
Note: this will even happen with stock suspension.
tombigbee
08-26-2014 07:14 AM
euroimport88
02-28-2011 10:56 PM
jaymac
04-26-2009 11:04 AM
avantgradeA6
01-10-2008 05:01 PM
Quick Reply: spacers what size???
