Strange Issue
Old Oct 21, 2011 | 09:16 AM
dafowler88's Avatar
Thumbs down Strange Issue
This only really happens when it's cool or cold outside. There is a weird varying hum that sounds like it is coming from underneath the rear passenger side seat. I'm not sure if that's really where it's coming from, it's hard to pin point. You can hear it from outside the car as well as from within. Has anyone else seen or heard of this problem? Thanks for the input.
df
Old Oct 21, 2011 | 09:19 AM
JoBuNY's Avatar
is it when you are driving? or when you are parked?
Old Oct 21, 2011 | 09:28 AM
dafowler88's Avatar
It does it in every gear when running. It's very bizarre. Sometimes it will go in and out when I'm driving down the road, it's almost like it coincides w/the revs. But not really all the time. Puzzling.
Old Oct 21, 2011 | 11:34 AM
jdahlen24's Avatar
Does it start at around 30 mph and seem to be change pitch as the speed changes? Sounds like it might be a rear wheel bearing.
Old Oct 21, 2011 | 11:39 AM
JoBuNY's Avatar
^^ Agree - if you are getting a "hum" noise while driving it's usually a sign of bad wheel bearing. That's why I asked if you were hearing it parked or while driving.
Old Oct 21, 2011 | 12:58 PM
dafowler88's Avatar
Yea, I thought about that. But it does it when in Park at idle. It almost sounds like something to do w/the exhaust. I'll take a video and post a link if the sounds comes through to video.
Old Oct 21, 2011 | 01:37 PM
JoBuNY's Avatar
OMG!!! LOL why didn't you put in the first post "noise happens while driving AND while in park"
Would have saved 4 needless posts :0)
Old Oct 24, 2011 | 11:58 AM
ilackav8's Avatar
sounds like fuel filter to me
Old Oct 24, 2011 | 02:16 PM
pa4ul's Avatar
Humming in the rear seat defintly a fuel filter. farily simple to replace also. But the part is expensive and no real way of getting around that.
Old Oct 24, 2011 | 03:11 PM
tmic0723's Avatar
I have the same problem but on the DRIVERS side. Last year I was told it was a cracked flex pipe...It was going to be like a 500 dollar fix I was told so I just skipped it at that point...
Eventually once it drops below 45 degrees permanently I'll have to get it fix. It's a really annoying noise.
