Stuttering when accellerating under load. HELP!!!!!
Hi guys,
This is just starting and it's not very pronounced but IT IS THERE.
When accelerating in either 3rd or 4th gear and going past 3000rpm, the car stutters just a bit. Enough for me to take notice. When I try to reproduce the problem I usually can't but it's happening every now and then.
I'm guessing one of my coil-packs is going as the last time I felt this was when I had the ECU flashed at TAPP Auto and I replaced all the coil packs to handle the increased load.
So thinking this I scanned the car but no fault was found as far as coil-packs go. Here is a copy of the scan.
Can anyone help me out?
VCDS Version: Release 10.6.1 (x64)
Data version: 20100831
Sunday,19,December,2010,17:11:28:23057
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: xxxxxxxxxxxxxx Mileage: 149200km/92708miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 F HW: 8E0 909 018
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 79410 154 402950
VCID: 336EF74C2B47
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
VCID: 26481E18E895
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 G
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
VCID: 254A19149593
1 Fault Found:
01592 - Air Quality Sensor (G238)
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul KAN 0305
Coding: 00004
Shop #: WSC 63351
VCID: 346CF4502E49
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
57-00 - Electric Circuit Failure
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 A
Component: Airbag 8.4E 3000
Coding: 0010607
Shop #: WSC 63351 000 00000
VCID: 356AC9542533
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
VCID: 3C7CDC700619
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D25
Coding: 03300
Shop #: WSC 00000
VCID: 29521524F98B
WAULC68E82A144025 AUZ6Z0A0281947
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
VCID: EBDEAF2CB3F7
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0617
Coding: 11852
Shop #: WSC 63351
VCID: 4280A28864FD
Part No: 8E1959801E
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802F
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801D
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802D
Component: Tõrsteuer.HR BRM 0002
5 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01331 - Door Control Module; Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 A
Component: symphony II NP2 0007
Coding: 00001
Shop #: WSC 00001
VCID: 254A19149593
1 Fault Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
End ---------------------------------------------------------------------
69 75 76 77
Coding: 0016701
VCID: 336EF74C2B47
Coding: 04275
Shop #: WSC 06435
VCID: 26481E18E895
Coding: 00000
Shop #: WSC 63351
VCID: 254A19149593
1 Fault Found:
Coding: 00004
Shop #: WSC 63351
VCID: 346CF4502E49
2 Faults Found:
35-00 - -
Coding: 0010607
VCID: 356AC9542533
Coding: 00041
Shop #: WSC 63351
VCID: 3C7CDC700619
Coding: 03300
Shop #: WSC 00000
VCID: 29521524F98B
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
VCID: EBDEAF2CB3F7
Coding: 11852
Shop #: WSC 63351
VCID: 4280A28864FD
Part No: 8E1959801E
Part No: 8E1959802F
Part No: 8E0959801D
Part No: 8E0959802D
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00001
VCID: 254A19149593
1 Fault Found:
Thanks for the reply mranthonyharvey,
I relaced the FF 2 years ago so I don't think it's that. Starting to wonder if it could be the Fuel pump but I'm more certain that it is a faulty coil pack. They tend to go quite often on the B6's
