Symphony sound fades in and out?
Old 06-21-2008, 08:48 AM
stevey1966's Avatar
Default Symphony sound fades in and out?
Guys, this is my first post so apologies in advance if its badly written etc. I'll learn! I'm running an S4 2004 model with the stock Symphony stereo (inc the in-dash CD changer), if I turn the CD volume over 16 then the sound starts to fade in and out - not completely it just gets slighly quieter for a moment, really irritating. I've tried fiddling about with GALA and the head unit has been changed once under warranty but its no better.
I used to have a TT with the Bose system - that was cool. I know the Symphony isnt all that great as a stereo, but hey most of the time I'd rather listen to that great V8 anyway...
Can anyone help? Is it just that the head unit cannot really cope with higher volumes (it doesnt distort though which is what I'd expect).
Thanks to anyone who replies.
Old 06-21-2008, 10:49 AM
swrt83's Avatar
Default RE: Symphony sound fades in and out?
Past 16?? Holy jeeze. I'm pretty sure I've never had mine above 12.. Anyway, it's is most likely related to this since you own an 04: http://dejong947.com/audi/tsb/audi.tb.91-04-17.pdf
Old 06-21-2008, 03:39 PM
04a430's Avatar
my symphony does this at low volumes, once past maybe 7-8, it will stop. Never had it happen up high. What is the deal with the SVC, I read a little about it, but didn't understand how to activate it. does the Audiopilot have to be disconnected for this to be enabled?
Old 06-21-2008, 05:28 PM
swrt83's Avatar
SVC isn't the issue, and no.. it can be enabled without having the audiopilot disconnected. The TSB soln is to disconnect the audiopilot to correct the error, and then simply re-enable the SVC is you still want the capability. Try going here, I posted the same problem not long ago..
http://forums.audiworld.com/audio/msgs/61449.phtml
Old 06-23-2008, 12:01 PM
hardenthefckup's Avatar
same issue here... the problem is the amp, its going out.
Old 06-23-2008, 01:38 PM
pa4ul's Avatar
have u tried further adjusting the radio. U have the hold the menu button down or something and it will bring up a screen with further adjustments. Thats the only thing i can think?
Old 06-24-2008, 11:05 AM
swrt83's Avatar
ORIGINAL: hardenthefckup
It's not that the amp is going out, unless you have a 1 off case. The 2004 has more than 1 mic to handle the volume inside and outside the cabin to adjust the volume in the speakers. When it's hot out your internal microphone has problems which affects the way it captures/reads/sends data to the amp inside the car. With the case of the OP, the volume is too high in the cabin so it tries to correct this hence the fluctuation.
Audi's TSB is to disable the audiopilot (i'm assuming this controls the internal mic's communication to the amp) to correct the problem. The CSV doesn't really have anything to do with this problem, but I guess when they disable the audiopilot the CSV is turned off by default, which is why they re-enable it.
The other solution is to replace your bose amp with a newer model since the new ones have corrected the problem through new firmware updates.. hope this clarifies
Old 09-06-2008, 04:01 PM
20percent's Avatar
Default bose? symphony?
i keep hearing you guys talking about the symphony being a bose stereo
i thought that they were two different units bose being the better of the two
people with the smyphony system are looking at the bose tsb
please set me straight
who is confused?
Old 09-09-2008, 02:53 AM
20percent's Avatar
anybody know im confused
Old 09-10-2008, 02:18 AM
20percent's Avatar
oh and where is interior body repair group 70 (the one you need to take off to get to the amp)?
rts9364
12-30-2015 12:12 PM
Joey123
03-24-2014 07:19 PM
avakhnin
12-17-2010 01:45 AM
GDuran144
B8 Models
02-17-2009 01:00 AM
FezA4
09-28-2004 03:32 AM
Quick Reply: Symphony sound fades in and out?
