timing belt, water pump seized
Old Mar 3, 2012 | 11:03 AM
PJS1995's Avatar
Default timing belt, water pump seized
'02 AUDI A4 QUATTRO, 4 CYCL.
engine overheated
engine shut off
timing belt teeth shredded off
water pump seized, unable to turn by hand or with channel locks
crank turns over easy, cam turns over easy without any problems
want to do compression check
starter spins without engaging the flywheel
bendix doesnt seem to be working
is there a safety cut out that is stopping everything from working??
Old Mar 3, 2012 | 02:14 PM
PJS1995's Avatar
Can somebody give me any advice to this post???? Please
Old Mar 3, 2012 | 04:03 PM
02A6Beau's Avatar
if you're timing belt is shredded the topside of your motor is most likely valve salad.
as for the starter, it is conceivable that it was damaged during the whole timing/waterpump/overheating fiasco but trying to diagnose what might be the problem, with the information you have provided is like asking me if I think that mole is cancerous
good luck
Old Mar 3, 2012 | 05:09 PM
M5S5's Avatar
Tech Certified
engine overheated
engine shut off
The engine is going to turn over very easy because it no longer has compression. Time to remove cylinder head & have it rebuilt or exchange it for a good one.
BTW also do the timing belt , water pump , thermostat, all rollers & tensioner.
Old Mar 4, 2012 | 06:58 AM
PJS1995's Avatar
THANKS GUYS, im doing a compression test this morning, i will let you know more, but i was affraid of this being the case...
Old Mar 5, 2012 | 01:01 PM
pa4ul's Avatar
did u drive you car even though it was telling you it had no coolant or did your timing belt just tear on you? ? It sounds like you are going to be in need of some major work.
madman1234509
Apr 22, 2009 11:11 PM
weezy
Dec 13, 2007 09:55 AM
Dj Spiel
Oct 9, 2007 09:08 PM
skatemerica155
Aug 31, 2007 11:46 AM
audigirl1982
Mar 29, 2007 02:08 PM
