Tires
Old Jun 1, 2011 | 12:42 AM
hihater's Avatar
Question Tires
So I need to get new tires soon. And I have a 2005 Audi A4 S-line with the Ultrasport package. So I have 18" rims. The OEM tire size for my wheels is 235/40/18. But I have a friend who can get me lightly used tires from a dealer for cheap, but they are 245/40/18. So it's a little wider. The guy claims to be a tire expert and says it will be fine on my car. But I have doubts, and think it will rub and cause problems when I turn. So will the 245 width be okay or a problem?
Old Jun 1, 2011 | 01:04 AM
Twistedfreedom's Avatar
the 245s will be 10mm wider than the 235s. As far as the heigh the tire, the 245s will be 2mm taller over all, they should fit just fine. It will depend on the back spacing of your wheel. and how much clearance you have between the strut and the tire now. If you have at least 15mm now between the strut and wire on the side and top you'll be ok.
Old Jun 3, 2011 | 03:52 PM
hihater's Avatar
Well I have the Ultrasport package, which I guess makes it look like an S4 but without the engine. So I think it's lower than a typical A4. Don't know if a bigger tire will cause problems, but if you say it's okay then I'll go for it.
bigatstyle
Nov 9, 2012 08:29 AM
dlyskawa
Dec 17, 2007 12:32 PM
pindonesia
Nov 16, 2005 11:43 PM
jmerrell
Aug 25, 2005 04:01 AM
miamitrails
Aug 17, 2005 03:08 PM
