Transmission filter change at 130k miles??? PLEASE HELP!!!!
Old Feb 10, 2011 | 12:49 PM
shane.trammell's Avatar
double post
Old Feb 10, 2011 | 09:37 PM
auditech79's Avatar
Originally Posted by shane.trammell
Would it be safe for me to do this on my 140k tip? I was discouraged from doing this by an audi tech at around 120k. He said I didnt want to lose the friction modifiers.
What, change the fluid and filter? Yes thats fine, you won't lose any friction modification by just replacing the fluid. If you're REALLY worried about it you can add a GM friction modifier, i usually add them to the Torsen diff because it quiets up the gears. Solvents are what removes the lubricants between the packs and destroys everything in a hurry.
Old Feb 13, 2011 | 09:51 PM
aamele8's Avatar
i know tell me about it thats why im afraid of.. but i want to do it because i plane on keeping this car for as long as i can and want to take care of it...
Old Dec 23, 2012 | 08:34 PM
2003audiA4avant's Avatar
Default Drain/FIll?
AudiTech you seem like a smart guy. mind helping me out?
I am going to drain and fill my tranny (with filter/gasket replace). I bought the kit from blauparts.com. Anyways I have a cheap vag com cable which will let me read the tranny temp so no problems there. My question is that I have a weird bucking issue. Almost like its losing fuel or spark, but it gets much better when the engine is warm. I have replaced ect, maf, cleaned throttle body, replaced air filter too.
So two questions.. Should I add some BG tranny conditioner when refilling or lucas oil or neither? (will it damage tranny components?
Also, what do you think of this buck? it drops like 300 rpm when is does and sometimes when shifting it will drop 500 then another 500 rpms, not just one smooth shift... I did the plug when i got the car but the coils were done before i had the car so not sure on that. Also, I use to get 2 codes for both my cats, but i dont get them anymore... not sure why. Thank in advance!
Se Shig
Apr 22, 2015 09:46 AM
littleflavio
Aug 17, 2008 05:45 PM
MPLSChase
Jan 15, 2008 05:39 PM
CaseyNPlano
Apr 9, 2006 04:49 PM
