Transmission Leak
Old Feb 3, 2009 | 01:39 PM
Agent1.8's Avatar
Default Transmission Leak
I was getting my oil changed yesterday (switched over to LiquiMoli 5w40 btw and I seriously felt better performance when I picked the car up) and I asked the mechanic to check the transmission fluid while he was doing the oil change, he said he could not check it because he needed a scanner to do so...anyway he said the the rear seal was a "little wet".
Now my transmission is not slipping at all, but I do want to make sure the fluid is good. Is there anything I should do? Should I replace the filter and fluid? I searched some other threads here and the transmissions seem to be very $$$.
Any help/advice would be appreciated...
Old Feb 3, 2009 | 04:49 PM
borninrussia3's Avatar
auto/stick?
Old Feb 4, 2009 | 07:28 AM
Agent1.8's Avatar
Originally Posted by borninrussia3
auto/stick?
Automatic
Old Feb 4, 2009 | 08:02 AM
well im not sure if theres a filter but if there is i replace and go with good quality oil preferably synthetic dont be cheap about it either. at a shop if u bring ur own parts the labor shouldnt be more than 40$...sorry dont know much bout automatic cars :I
Old Feb 5, 2009 | 11:47 AM
FOURFUN's Avatar
just had mine done $300 to change seal/ cannot access the filter without removing trans/ stick to oem fluid you will need about 3 1/2 liters if you drain from drain plug
Old Feb 6, 2009 | 10:57 AM
Agent1.8's Avatar
So i think I will follow what you did, have the seal replaced, and have the fluid and filter changed, just to be safe, thanks for the help...
Old Feb 6, 2009 | 11:26 PM
BerkeleyA402's Avatar
let me know if that fixes the leak. I'm sure I have the same problem. I also went in for an oil change and noticed some transmission fluid on the rear of the transmission.
If you buy the parts online, please send the link. I can't seem to figure out which is the correct part.
Old Feb 9, 2009 | 09:15 AM
Agent1.8's Avatar
It is at the shop now, I will let you know by this afternoon...
Old Feb 9, 2009 | 11:06 PM
wolfdog's Avatar
I am not 100% sure on the autos but at least for the manual, Audi claims it's lifetime transmission fluid (to keep advertised cost of maintenance down?). I replaced mine at 75k miles. Autos are probably more difficult to DIY so perhaps you should just pay them to do it.
Espirit
Aug 5, 2012 04:00 PM
BFM
Jul 17, 2008 02:38 AM
dhruv42
Jun 25, 2008 10:33 PM
silveraudib6
Jun 23, 2008 03:53 AM
s4avant
Feb 28, 2006 03:16 AM
