Trany problem - P0706
Old May 9, 2012 | 09:11 AM
ilackav8's Avatar
CVTs are widely known for failures, and frequently cited as "when, not if they fail." read up on all the threads in the b6 forums where others have shared their tribulations with this transmission. i know there are a lot of them.
the most common issue is the TCM, and it is a lot of cash. i'd also be prepared for a very expensive rebuild or replacement in the future. audi has known about the problem for years, and there are no recalls on the matter, so don't bother trying to contact AofA about it.
if the lights aren't flashing now, the shop probably cleared the faults when it was diagnosing your codes, so they will likely come back.
sorry to share the bad news, but it's a fact of life cvt owners have to face.
Old May 9, 2012 | 10:30 AM
eek's Avatar
eek
Originally Posted by Milind
I bought used audi A4 1.8 T cvt 2003 with 71000 miles, i drove it for 30 miles without any issues, tried to start car and PRND stared flashing. i changed the oil and spark plug, now the PRND is flashing intermittently. I dont see any issue with driving, cars goes above 40 mph with rpm being below 2000. I took the car for inspection to independent auto work shop he is quoting 2900 for replacing TCM and flushing transmission oil for fixing P0706 code, is this right quote for replacing TCM? I took the car out of this shop drove for 17 miles now check engine light and PRND are not flashing, could this be some issue with wiring? or with transmission oil? please help me with your valuable suggestion.
Did you check the connector that connects the TCM to the transmission. If there is water or moisture it wii short out some signals...placing the traansmission in Fail safe mode and the flashing will start. Can you reverse?
Old May 9, 2012 | 11:57 PM
Milind's Avatar
I dont know how to check the connector, where is it located? I can reverse the car even when the PRND is flashing, I drove the car about 24 miles since yesterday. car goes above 40 mph without issues. for once since yesterday i saw once the car will not go beyond 20 mph, but when i started again later i was able to go beyond 40 mph.i think something is acting wierd.
Old May 10, 2012 | 05:50 PM
eek's Avatar
eek
The connector is on the transmission itself. it is circular and it is on a lead at the end of the transmission computer module, hence TCM.
A mechanic will have to get at it.
I have pictures and will enclose, once I found them....hold on.
Old May 11, 2012 | 01:32 AM
Milind's Avatar
Thanks for reply, today I drove car 6 miles to office, and back to home, no issues, PRND did not flash. but when tried to take the car out later in evening, I found the following observation
Key in Run Position, all PRND were displayed inverted, I tried to shift the gear, the Inverted display was for P and R gear when i move the Gear shifter to N and D display was proper. I started the engine moved the gear to R I was able to reverse the car and drive it however now PRND started flashing. I could not feel the transmission was in limp mode.
I found nice PDF explaining the multitronic transmission on internet this one shows 25 pin connector is this the one you were talking about? : http://www.volkspage.net/technik/ssp/ssp/SSP_228_d1.pdf
Old May 16, 2012 | 12:55 PM
Milind's Avatar
I am observing that PRND only flashes when i drive car come to standstill, and then shift the lever from D to P. and then when i try to start the car the PRND continue to flash, and then after few miles of drive flashing of PRND stops when the lever is in D.
Old Jun 5, 2012 | 10:15 PM
dotpage's Avatar
Anyone found a dealer or shop that did the repair? If so, how much did it cost you? Thanks in advance!
Old Jun 8, 2012 | 07:31 PM
  #18
luissalman's Avatar
Default repair TCM CVT module shops
hi, i just found this at ebay, and i'm sending my TCM next week, i'm also found another cheaper in United Kingdom, i'm posting both links, hope this can help you.
Audi A4 Temic Transmission Control Module Repair Service TCM CVT | eBay
Audi Multitronic Gearbox ECU 01J927156HH / 01J927156HT | eBay
Old Jun 9, 2012 | 12:38 AM
  #19
dotpage's Avatar
Thanks for the links, however, it seems like Audi is trying to do the right thing, reducing the repair to a little over $1K including labor, and they guarantee the repair for 1 year... sounds descent to me..
Old Jul 31, 2012 | 08:29 AM
  #20
silverone's Avatar
i have a 2004 A4 170000 km it has gone through 3 brand new cvt transmisions dealer installed and the tcm reflashed twice and now the transmission is gone again. audi canada washed their hands and im stuck with a 7000 dollar repair on a 6500 car. oh and i tried rebuilding the tcm at XeModeX twice. UseLesS. i hope you have better luck than i did.
Misak
Jul 16, 2015 10:22 PM
Cuda66
Jul 17, 2013 12:20 AM
MADCOBRA03
Jan 26, 2010 07:51 PM
singletrac
Sep 10, 2009 06:50 PM
kakashisan
Dec 24, 2007 03:21 PM
