trip-tronic won't shift
Old Jan 9, 2009 | 12:34 PM
Rolling Blackout's Avatar
Default trip-tronic won't shift
When I leave the trans in drive, it works just fine, but if I try to manualy shift it, it won't shift until it revs out. Has any one else had this problem? The car is a '04 A4 3.0 quattro.
Old Jan 9, 2009 | 12:51 PM
AutoUnionFan's Avatar
Did you try searching? ... no
check out the links in this thread:
https://www.audiforums.com/forum/sho...ptronic+broken
Old Jan 9, 2009 | 12:53 PM
shane.trammell's Avatar
Sometimes mine won't shift up at the stick, but still does at the buttons on the wheel. My problem seems to be a sensor or switch.
Old Jan 9, 2009 | 01:57 PM
I did try a search, but did not come up with that same tread, guess I didn't use the right words.
Thanks AutoUnionFan
Old Jan 9, 2009 | 02:50 PM
your welcome
"tiptronic broken" was my search string
Old Jan 14, 2009 | 09:15 PM
So I took apart the shifter, it looks a little different, but came apart the same way. I was expecting to find the magnets gone, but they are still there. I'm wondering if it could be something in the computer? Would this cause any codes to come up?
Old Jan 15, 2009 | 10:22 AM
SunnyShaida's Avatar
What's that rubber part from you shifted called (the second pic in ur thumbnails), mine seems to be messed up it's almost tearing and I feel resistance putting it into park
1fastTT
Jun 11, 2009 07:05 PM
AdamL
Apr 2, 2009 09:46 PM
neomaxddr
Mar 22, 2009 09:03 PM
starting...
Feb 7, 2007 04:15 PM
707782y
Mar 16, 2006 01:45 AM
