Turn signal ghost!!!
Old Mar 20, 2009 | 07:59 PM
zippy_gg's Avatar
Question Turn signal ghost!!!
I left my 2005 A4 3.0 Tip with a dealer who "tried" to sell it for me for several months.
Last Saturday I went to pick it up and found that the battery was flat dead! $152.00 later the car started but I also found that my passenger HID low beam was dead. The coolant reservoir was empty, and the tires seriously deflated. I bought a replacement DS1 for $60.00 on eBay and everything is fine... or is it?
When I use the left turn signal, all is fine.
When I try to use the right turn signal I get the first flashing on the right but then it switches to the left. Yes, using the right turn signal will make the left flashers go! WTH???
I was wondering if there was a pending technical bulletin for this. I mean we are talking about a potential accident waiting to happen here!
Has anyone seen anything like this? The car just turned 27k miles and is otherwise in perfect condition.
Old Mar 30, 2009 | 11:36 PM
gnarpow's Avatar
Believe it or not I have had the same problem. Fortunately I was under warranty. I am not sure of the exact fix to the problem but they did need to remove the entire dash in order to replace a part (or at least thats what i was told). Hopefully you can find an easy fix.
Old Mar 31, 2009 | 01:04 AM
auditech79's Avatar
Its just a fault turn signal stock, and no you don't have to remove the entire dash board, the techs write a elaborate story for the warranty clerks so they get paid more. If they say they took this apart (but actually didn't) they get paid more. Get it?
Old Apr 1, 2009 | 11:56 PM
zippy_gg's Avatar
The turn signal issue seems to have resolved itself after I drove the car for a couple of days...
Oh well, I guess that's a good thing.
Old Apr 2, 2009 | 12:54 AM
auditech79's Avatar
Try tapping on the fender that doesn't work if it happens again. Its common for the bulb socket to go bad on B6 A4's.
mrdb85
Aug 17, 2008 04:24 PM
JETSPEED333
Jun 26, 2008 05:42 PM
ALL*AUDI
Jun 4, 2005 11:56 AM
paliracer
Feb 21, 2005 03:15 PM
