Turn Signals Osciallate Between Right and Left
Old Jul 30, 2009 | 05:28 PM
Orange's Avatar
Default Turn Signals Osciallate Between Right and Left
This is a very odd problem that I'm having difficulty diagnosing.
I have a 2002 Audi A4 that I recently purchased. It's in pretty perfect condition, except for this turn signal business. Every now and then (several times per drive), when I activate either turn signal (fully clicked into position, not just holding it for a lane change), my turn signals oscillate (on tempo, neither too fast nor slow) and then fix themselves - they'll blink left, right, left, right, left, left, left...
I've been pulled over once already for improper signaling. No ticket, but still.
I'm not a car guy, so I don't really even know where to start finding the problem. Any ideas? The ECU has been upgraded, although not by me and I do not know which unit he selected. Could that be the culprit?
Old Jul 31, 2009 | 12:24 AM
Midniteoyl's Avatar
Sounds like the turn signal relay. Dont know where its at on your car, however. You can turn it on and listen for it though.
Old Jul 31, 2009 | 02:25 AM
Dan1969's Avatar
You know if you just move your clicker to the position it'll click 3 times on its own, without locking it or holding it in place, if you move it the other way it'll finish the clicking and then go on to the other side on its own. But if you're just moving the arm to one side and your lights are still blinking both sides I would check the relay (clicker) thingy.
Old Jul 31, 2009 | 12:04 PM
Orange's Avatar
Yes, I do know this. Its actually a pretty smart feature.
I have tried to listen to see if i can notice anything at all, but like I said, the oscillation is on tempo - there isn't any perceiveable audio problem with the click of the relay.
Are you saying that it would oscillate? That is the problem that I have - when I select the left signal change position it'll do this:
L R L R L L L L ...
It sounds like if we think its an automatic three-blinks thing, then, as you said, wouldn't it "finish and go on to the other side on its own" ?
What might I do to help diagnose if this is the relay or not?
Old Jul 31, 2009 | 10:12 PM
Dan1969's Avatar
I got a L, L, L, then R, R, R, nothing in between. Try changing the clicker or look in your fuse box make sure that all fuses are fully inserted.
Old Jul 31, 2009 | 10:23 PM
Midniteoyl's Avatar
Heh.. I ment listen for the relay so you can find it and swap it out.
The other thing it could be is the switch in the stalk itself.
ed1404
Jul 20, 2011 01:08 AM
never_enough
Jun 18, 2009 12:11 PM
wootang71
Aug 11, 2008 12:50 PM
audistud13
Mar 8, 2007 06:34 PM
grapejuice
Jan 9, 2006 09:03 PM
