Vacuum Check Valve
my vacuum check valve was all melted so i just replaced it with a straight piece for now....i checked and the part is 30 bucks....should i replace this? is it necessary, what the hell does it do? seems like it just limits airflow
http://www.usplastic.com/catalog/pro...oduct_id=15641
I believe I got the 1/4" Kynar ones. They hold up to heat better.
i found out what use they have...theyre one way valves so only aloowing air to go in one direction and not return...and they are somehow needed for your turbo to work otherwise i think you loose serious boost
^^^Some people get rid of the WHOLE old vacuum lines system
here http://www.audizine.com/forum/showthread.php?t=235106
more info about check valves http://www.audizine.com/forum/showth...ht=vacuum+line
