Weak heat output?
Old Dec 28, 2010 | 07:06 PM
allen vasser's Avatar
Default Weak heat output?
My check engine light is on and weak heat output. Code is a PO3081.
Had a repair shop replace coolant plug near Tstat housing since it was leaking. While they were there the Tstat and new updated housing w/sensor was replaced. NO coolant leaks now , a test drive and the check engine light is back on with same code and heat is better but still not warm at idle.
The tech said there is TSB on that same issue that I have for my car with poor heater output. Any Help would be appreciated from someone with more Audi Technical experience.
euroimport88
Nov 2, 2010 02:56 PM
cu52
Oct 28, 2009 11:50 AM
dannebrog
Jan 6, 2008 12:26 AM
fatchoyking
Dec 31, 2007 09:12 PM
kwsmithphoto
Nov 25, 2007 02:17 AM
