Weird Rattle, starter?
Old Jan 22, 2009 | 10:15 PM
kerNol's Avatar
Default Weird Rattle, starter?
So recently I began to pick up a rattle especially when cold and it sounds like its coming from down near the starter. I did the old stethoscope trick with a long screw driver to find the origin of the noise and no luck. It's not from the cat, turbo or even the cam tensioner. Zero noise from those points, now I can't get down to the starter to really hear but it sounds like something in that area. I've even checked the heat shields and nothing. Any ideas? Anyone run into anything on their starters like the engagement sprocket that get shitty?
Thanks
Old Jan 27, 2009 | 05:08 AM
handyvorb's Avatar
Engine code would be helpful here...
The noise you're describing sounds a lot like the idler puller for the ribbed belt (accessory belt). I've replaced a lot of them for this. With the engine off (I have to say it ) reach down to the pulley and try to wiggle it, it should have no play whatsoever.
Old Jan 27, 2009 | 09:24 PM
kerNol's Avatar
AMB engine code. I'll look tomorrow.
imaudi5000
B7 Models
Jun 19, 2014 10:11 PM
moneyfresh
Dec 15, 2012 02:01 AM
fullcollapse318
Sep 21, 2009 07:46 AM
seanmh
May 27, 2009 04:05 PM
mtnxtreme
Jul 19, 2008 11:32 PM
