What to look for?
Old Aug 6, 2009 | 09:56 PM
wolfdog's Avatar
Main issues:
-timing belt done ~75k but definitely before 100k.
-rear coolant flange, feel around at the back to see if oil is leaking. Easy DIY fix but worth checking.
-check to see if the coilpacks are revision R. L is teh old stock version. Ask when they were last changed, if ever. No big deal if they weren't.
-pull the coilpacks and look down to the spark plugs to see if there is any oil. If so, the valve cover gasket may need to be changed. Again, easy DIY.
-when test driving, roll windows down to listen for noises in the turns. do it while going slow and with wheel turned pretty far.
-inspect tire wear since the quattro can go through tires, especially if not aligned properly
-make sure only synthetic oil has been used
-check AM/FM reception because antenna booster above rear window cracks and stops working with time
-sometimes radio and similar buttons peel
That's all I can think of right now.
Old Aug 7, 2009 | 01:29 AM
Leadfoot'er's Avatar
Originally Posted by wolfdog
Main issues:
More than helpful,thanks..
If the wheel do make noise when I turn slowly what would be the prob?
Old Aug 7, 2009 | 11:34 AM
pa4ul's Avatar
powersteering fluid or pump failiure
Old Aug 7, 2009 | 10:02 PM
wolfdog's Avatar
it would point to potential issues with control arms, wheel bearings, etc.
Old Aug 8, 2009 | 09:14 PM
Ok tht doesnt see to b a prob..On th one i plan to get,when the turbo spools i hear a little fast ticking sound tht only happens when it spools,what could that be?
Old Aug 8, 2009 | 09:17 PM
wolfdog's Avatar
I'm sorry, I don't have a clue what that could be.
Old Aug 8, 2009 | 10:57 PM
Ok kool.Im just gonna have to look tht up..
