Wheel bearing issue
Old Nov 9, 2009 | 09:22 PM
ntriska's Avatar
Default Wheel bearing issue
So I was attempting to change my front wheel bearings and I stripped one one of the out. Does anyone have any recommendations on how to best approach this. Also, on the passenger side I was able to remove the 4 bolts (triple square 12MM). Is there anyway to not have to remove the entire arm that the hub is pressed into or will I eventually have to do this? Any help is appreciated! BTW I have a 2004 A4 Quattro 1.8T.
Thanks,
Nathan
Old Nov 9, 2009 | 10:29 PM
Dan1969's Avatar
I know most people just remove the tie rod and the bottom bolt, but that's for the CV boot/axle. I don't know about the bearing.
Old Nov 10, 2009 | 07:24 PM
ntriska's Avatar
Thanks for the info. Do you have any idea on the pinch/knuckle bolts how I need to approach them. For example, at the top of the spindle where the upper control arm and something else are attached and a pinch/knuckle bolt is on it as well...do you know if all bolts have to be removed in order to completely remove the spindle?
Thanks
Old Nov 11, 2009 | 05:15 AM
Dan1969's Avatar
No not really, I hear they're a pain on the older models, I don't really know about ours. I haven't done it myself on my A4, did it in a Primera before and that was a pain.
Kyle_vdk
Jan 11, 2014 10:25 PM
A4dable
Apr 24, 2009 09:05 PM
spongebob
Jul 8, 2008 09:33 PM
