Where do i fill my transmission with fluid??? Please help
Old Feb 13, 2011 | 01:46 AM
aamele8's Avatar
Default Where do i fill my transmission with fluid??? Please help
HI 2002 A4 3.0 QUATTRO A/T here .. can anyone tell me or show me with pictures where it is the i can fill my transmission with at fluid..
thanks in advance
Old Feb 13, 2011 | 09:24 AM
460Jetboat's Avatar
First, what makes you think it is low on fluid?
In answer to your question, there is a recess in the bottom of your transmission pan with a large allen in the recess.
This is where you fill it by pumping trans.Fluid into the hole.
The car must be level, and up to operating temperature when you fill it.
You fill it until it runs out of the hole with the allen removed.
The proper procedure is to connect a VCDS, and monitor the transmission temperature and fill it at the specified temperature.
I would also strongly suggest you go to your dealer and get factory fluid, as mixing brands would probably not be a good idea.
If your car has close to 100K miles on it, it would be a good idea to change fluid & filter.
Old Feb 13, 2011 | 10:06 AM
aamele8's Avatar
No i dont think its low ,,, i just wanted to know for future reference because im really confused and undecided on changing the fluid and filter because it has 131k on it and dont want to loose the friction between gears if i do .. do you think its safe for me to do it? please let me know thanks...
Old Feb 13, 2011 | 01:47 PM
auditech79's Avatar
If you're not familiar with it or experienced with a vag com, then no its not very safe for you to do it yourself.
Robin Schroeder
Mar 4, 2011 03:33 PM
vtraudt
Dec 13, 2010 08:18 AM
fromerich
May 9, 2010 08:48 AM
mach1usmc
Sep 3, 2007 12:01 PM
cary12
Dec 4, 2006 05:49 PM
