Window frame dissasemble to replace regulator ?
Old Sep 23, 2008 | 10:12 PM
PCA4's Avatar
Default Window frame dissasemble to replace regulator ?
Hello,
My green clip (on window regulator) snapped on passenger rear door. Bought OEM part and have the door panel off. I understand i have to remove the window frame to replace the regulator. I have removed the light green torx screws and i get some play but the frame will not lift up and out. I have removed the lower screw that attaches the regulator frame to the shell also. I've been through numerous threads that discuss the regulator needing to be replaced but no detail on how to remove the window frame to get to the screw that attaches the top part of the requlator to the frame. Any insight to screws i have missed or additional help ?
thanks in advance.
Old Sep 23, 2008 | 10:19 PM
auditech79's Avatar
Old Sep 23, 2008 | 11:17 PM
PCA4's Avatar
Thanks for the quick reply.
The schematic you sent is for the front left door. I am working with the right rear door. Can i assume the screw placements are the same and just flip flopped ?
thanks again.
Old Sep 23, 2008 | 11:23 PM
auditech79's Avatar
Pretty much the same thing except there are a few less bolts.
Old Sep 23, 2008 | 11:34 PM
PCA4's Avatar
Thanks again !
Will tackle it tomorrow. Gotta love the quattro. Moved up here to Park City, Utah from Illinois last winter and the A4 ripped thru all the snow we got last year. You otta consider opening a sister shop out here. The dealers are 2 weeks out on service calls and non dealers are 4 weeks out. Lotta Audi drivers and not enough qualified mechanics.
Old Sep 23, 2008 | 11:39 PM
auditech79's Avatar
Indy audi mechanics won't be able to cut it in later years. Audi specifically makes special audi tools to work on componets on all their new cars that you have to buy to work on them. Dealers spend hundreds of thousands of dollars on audi specific tools every few years. I wouldn't be able to keep up, other manufactures are following this example as well.
Old Apr 13, 2010 | 07:46 PM
drifter22's Avatar
Member
Here is a link for the dreaded rear window http://www.audiworld.com/tech/int66.shtml
pisceswheels93
Jun 19, 2014 08:37 PM
Rn3037
Feb 1, 2012 08:21 PM
h4x0r
Dec 31, 2011 12:20 PM
ppgoal
Jan 30, 2009 12:49 PM
triplerr
May 10, 2008 05:52 PM
