07 A4 - RPM Surge between gears
Old Aug 28, 2012 | 02:07 PM
mtasabat's Avatar
Default 07 A4 - RPM Surge between gears
Hey guys,
I'm hoping you can help here. I have an 07 A4 Avant 2.0T 6spd Manual. Just yesterday I started having an issue where the RPM's surge between gears. Especially when shifting from 2nd to 3 gears. It's resulting in a choppy shift and I can't get my head around what may be the cause. I'm thinking it may be related to the blowoff valve, if it may be a little gunked up, or the turbo. It behaves normally when on and off the throttle either in neutral or while driving in gear, and I only notice this behaviour when shifting gears. Any insight you guys can provide would be really helpful.
Cheers,
M.
Old Aug 28, 2012 | 02:54 PM
Damaniac311's Avatar
Sounds like it's possibly your clutch switch. Happened to me....they can stick and cause this. Try your cruise control, if that doesn't work that's also indicative of a failing switch. 5-10 minute job.
http://www.ecstuning.com/Audi-B7_A4-...tch/ES1862302/
Cheers.
tomo5011
Aug 6, 2012 09:29 AM
TomoChubachi
Jul 3, 2008 12:38 AM
nick17
Feb 19, 2008 10:23 PM
scottlt79
Dec 31, 2007 11:38 AM
bahndrvr
May 10, 2007 05:20 PM
