2006 a4 2.0t timing belt
Old 10-27-2008, 04:46 PM
OOOOA4's Avatar
Question 2006 a4 2.0t timing belt
My 2006 A4 has 75k miles on it and the dealer says my timing belt needs to be replaced.
the estimate is $1,400. Does this make sense? Should't a major engine component last longer than 75k miles? This car has been babied and rarely goes over 2000 rpm.
Old 10-27-2008, 05:44 PM
eMacPaul's Avatar
I don't know about actual failure, but 75k is when the service manual calls for it to be replaced. And if perchance you don't replace it and it does fail, you could be looking at a lot more than $1,400.
Old 10-28-2008, 12:21 AM
cgmiller63's Avatar
Perhaps you can have it replaced at an independent repair shop for less than $1400. It's worth looking into.
Old 10-28-2008, 12:29 AM
dmfan016's Avatar
75k miles is about right for a new timing belt.....they can last up to 100,000 but if your timing belt breaks you don't have an engine anymore....the valves will fall into the combustion chamber and pistons will slam them against the top of the engine...thus....no more engine....ever....at all.....non repairable....
so you gotta ask yourself....is 1,750 worth it for your a4 to carry on for another 75,000 miles?
Old 10-28-2008, 07:38 PM
ocadam's Avatar
does that include the water pump?
Old 10-28-2008, 11:03 PM
dmfan016's Avatar
the part plus labor is prolly around 1750....a timing belt isn;t exactly the easiest thing to replace....its location is really hard to get to and installing it properly is hard enough
Old 10-30-2008, 06:22 PM
OOOOA4's Avatar
This morning I made an appointment to get the belt replace this Tuesday. Then later this afternoon the service advisor at the dealer called and said that my 2006 with the 2.0TFSI engine does not need the belt replaced until 110,000 miles. He said that on 10/27/08 Audi USA sent them a revised maintenance schedule for 2006 Audi cars which shows the revised mileage for my car. He faxed this over to me today.The 2006 A4 convertibles with the 1.8T engine will still need the belt replaced at 75,000 miles.
Old 10-30-2008, 07:31 PM
cgmiller63's Avatar
Good to know. Can you scan the copy he sent you an post it here or e-mail it to me? I'd like to keep something like this in my file. I'm not sure all stealerships would be so honest.
Old 10-31-2008, 12:11 PM
OOOOA4's Avatar
The copy I got was poor quality small print. I had to enlarge it 200% on the copy machine to read the portion that applied to my car. When I go to the dealer on Tuesday I will try to get an original to send you.
Old 10-31-2008, 07:16 PM
cgmiller63's Avatar
Thanks.
Quick Reply: 2006 a4 2.0t timing belt
