2008 Audi RS4 -- rough starting and misfire
Old Mar 18, 2016 | 05:22 PM
Kellyberjak's Avatar
Exclamation 2008 Audi RS4 -- rough starting and misfire
Hi everybody I have a 2008 Audi RS4 with 108KM = 68Miles. I changed the coil packs and spark plugs two months ago. I also added injector cleaner to the gas tank all within the last month. However my car still takes a while to start sometimes and cranks for a while. It sometimes idles rough for a couple seconds right when the engine ignites and the engine light comes on and it says multiple cylinder misfire and codes like p0300, p0304 and p0307. I turn them off then a about a week later same thing. Any suggestions what it can be? I already changed the spark plugs and coil packs. Thanks !!
Old Mar 18, 2016 | 09:45 PM
KingWulfgar's Avatar
I'll be honest, you may not get much traction with this here. Those are pretty generic codes and the RS4 is pretty rare (not a lot of technical knowledge about them here).
Since you already changed the plugs and coil packs, it's possible it could be a fuel problem, but you should also be getting other codes as well if that's the case.
You could also try over at AudiWorld--they have a dedicated S4/RS4 forum that seems to have some life. There are S4 and RS4 forums here too, but they are not super active.
Sorry, I hope you get it sorted!
Old Mar 19, 2016 | 11:20 AM
rhodes991's Avatar
I was going to add that is reads like when my diverter valve went bad, except I didn't throw codes. If I were to guess (and I am) it seems to be a fuel issue. Maybe not enough fuel pressure causing delayed starting and the shuddering at start up?
Old Mar 19, 2016 | 02:15 PM
Do you have a ball park of how much that will cost ?
Old Mar 19, 2016 | 10:23 PM
rhodes991's Avatar
Diverter value is about $60 if I remember correctly and is pretty easy to replace. Not convinced that is your issue though.
Old Mar 24, 2016 | 10:52 PM
imaudi5000's Avatar
have ya changed the fuel filter? even with using cleaner, a bad filter could cause flow issues. just my guess
WowA6Cool
Nov 6, 2016 01:42 PM
alexflan
Sep 29, 2014 06:52 PM
frizle2001
Jul 25, 2009 01:41 AM
whitejeepXJ
Sep 26, 2008 06:46 PM
JohnnyBravoA4
Jan 10, 2007 02:58 PM
