Rough rough rough
Old Sep 25, 2008 | 09:33 AM
whitejeepXJ's Avatar
Default Rough rough rough
Hi,
Last couple of first starts of the day I get a fairly rough idle when in fast idle and a flashing CEL. After it warms up it idles at the normal level but after about 10-15 seconds of that it starts to get rough again.
Is this caused by O2 sensors on their way out? If so, which one(s) usually go bad?
Specs: 2001 A4 1.8tqm 110,000miles.
Thanks,
Mike
Old Sep 25, 2008 | 10:22 AM
McGovs2.7TB5's Avatar
Flashing CEL usually means a miss fire. Get the codes read and report back when you've got them.
Old Sep 25, 2008 | 06:34 PM
ghost6303's Avatar
if the problem with your o2 sensors, the pre-cat o2 will cause the car to run bad. the post-cat sensor is just to check the efficiency of the cat and doesnt have any input on how the engine runs.
Old Sep 26, 2008 | 12:30 AM
MrFlippant's Avatar
Rough - just the way your mother likes it, Trebek! HAHAHAHAA!!
Old Sep 26, 2008 | 02:10 PM
SLOJoe's Avatar
Member
I'll take The rape ist for 600. That's Therapist Mr. Connery.
What the weather like where you live? Very very cold or what?
-Joe
Old Sep 26, 2008 | 04:11 PM
ghost6303's Avatar
lol i was going to post that but figured it might be offensive if the OP hadnt seen the show.
Old Sep 26, 2008 | 04:34 PM
UPDATE: I scanned the car and had a misfire in cylinder number 3, changed the pack and all is well. The cause of the rough idle was oil on the tip of the coilpack, I need to change the valve cover gasket, it leaks into the holes where the sparkplugs are.
Thanks guys,
Mike
Old Sep 26, 2008 | 06:46 PM
MrFlippant's Avatar
^^Awesome! Glad I could help...
quattroforthewin
Mar 28, 2011 03:46 PM
cwilliamsccn
Feb 18, 2011 07:21 PM
teranenrique
Sep 9, 2007 07:43 PM
AudiStar
Jun 12, 2007 10:02 PM
auDi1.8TQ
Nov 16, 2006 04:35 PM
