55K Service
Old Jan 28, 2012 | 10:35 PM
ccmnova's Avatar
Default 55K Service
08 A4 2.0T - looking for the specifics of 55K service. Thinking I can do it on my own.
Old Jan 29, 2012 | 12:22 AM
eMacPaul's Avatar
55,000 miles (85,000 km) or 1 year after last service, whichever occurs first
Engine oil / Oil filter - Change oil and replace filter.
Engine - Check for leaks.
Service reminder indicator display - Reset display.
Dust and pollen filter - Replace filter.
Snow screen for air cleaner - Clean (where applicable).
Brake system - Check for damage and leaks, thickness of pads and brake fluid level. Wiper arm pivot points - Lubricate.
Check the following:
– Cooling system - Check coolant level. Add coolant if necessary.
– Battery - Check and replace if necessary.
– Exhaust system - Check for damage and leaks.
– Engine - On board diagnosis, check fault memory. (except Audi Q7)
– Windshield wiper and washer / Headlight washer - Check adjustment and function and add fluid if necessary.
– Automatic transmission and final drive - Check for leaks.
– Manual transmission and final drive - Check for leaks.
– Tires and spare wheel - Check for wear and damage. Check tire pressure. Check renewal date of tire repair set (where applicable).
– Doors - Lubricate door hinge mechanisms.
– Sunroof - Clean guide rails and lubricate.
Old Jan 29, 2012 | 10:55 AM
ccmnova's Avatar
Thanks for this list - someone mentioined to me that plugs, fuel filter etc would need to be changed but I didn't think so.
I printed this out and will take care of the main items.
Old Feb 7, 2012 | 12:10 PM
alonebb's Avatar
i see, does 55k service charge included all the replacement like Windshield wiper & filters?
Jedward02
Feb 4, 2009 10:30 AM
DarkHelmet
Jul 24, 2004 09:46 PM
