Audi A4 2.0tdi hard start on half tank
Hello, i just bought a 2008 audi a4 2.0tdi. And it starts rough on low tank, it gets worse and worse the less i have in the tank. Also when i have full tank, it starts fast but still «hard» please help
It can be couple reasons:
I'd recommend you to start with checking Fuel Pump And Filters.
- Fuel System Issues:
- Fuel Filter: A clogged or dirty fuel filter can restrict the flow of fuel to the engine, especially when the tank is low. It's a good idea to check and replace the fuel filter if it hasn't been done recently.
- Fuel Pump: The fuel pump might not be delivering an adequate amount of fuel to the engine. If the pump is failing, it could cause starting issues.
- Air Intake System:
- Air Filter: A dirty or clogged air filter can affect the air-fuel mixture, leading to poor combustion and rough starts. Make sure the air filter is clean or replace it if necessary.
- Glow Plugs (Diesel Engines):
- If your Audi has a diesel engine, check the glow plugs. Faulty glow plugs can cause difficulty starting, especially in colder conditions.
- Injectors:
- Malfunctioning fuel injectors can lead to poor fuel atomization, impacting combustion. Consider having the fuel injectors checked for proper functioning.
- Evaporative Emission System:
- Issues with the evaporative emission system, such as a faulty purge valve, can affect the fuel vapor management and cause starting problems.
- Engine Control Module (ECM) or Sensor Issues:
- Problems with sensors like the crankshaft position sensor or the engine control module can impact the engine's ability to start smoothly.
