Best brake pads to eliminate squeal?
Old Feb 20, 2008 | 09:35 PM
spex's Avatar
Default Best brake pads to eliminate squeal?
The brakes on my 2006 2.0T A4 squeal like crazy. Dealer says brakes are fine (both pads and rotors) and that the squeal is "normal". I'm hoping new pads will get rid of the squeal. Can anyone recommend the best pad-only upgrade that will fit my model? I want no squeal and would prefer to not lose bite or braking power. Car is for normal street use - no tracking.
Old Feb 20, 2008 | 09:46 PM
ocadam's Avatar
Default RE: Best brake pads to eliminate squeal?
Hit the search tab up top. https://www.audiforums.com/m_12749/tm.htm
Your new so dont worry about it. I also think i have heard that cearmic pads are good they will cut down on the dust as well.
Old Feb 20, 2008 | 10:26 PM
spex's Avatar
Thanks Ocadam. I've actually been through all that (rotors and pads are supposedly fine, had them cleaned, sprayed, chamfered, etc.) I've also repeated the bedding just in case. At this point I'm ready to try swapping in new/better pads. I've heard Akebono Euro-ceramics are best for this, but they don't make them to fit my car. And I thought a post dedicated strictly to pads and pad materials might hijack the thread you referenced.
Has anyone out there cured similar squeals simply by swapping their pads? Care to share which pads did the trick?
Old Feb 20, 2008 | 10:45 PM
ocadam's Avatar
Just post a thread in the B5 section.
jinsojoo
Sep 16, 2021 04:49 PM
Soundchasr
Nov 16, 2010 08:24 PM
cantdrive55
Aug 28, 2010 02:01 AM
jmthom
Oct 18, 2007 10:00 PM
black b5
Jun 1, 2005 09:36 PM
