Cabriolet roof not locking down
Old Nov 1, 2017 | 05:12 PM
newsrus's Avatar
Default Cabriolet roof not locking down
About 75% of the time, when I open the roof it doesn't close properly. When that happens, the roof will operate normally - until the deck closes. Sometimes, it will go all the way down and lock in place but mostly the locks do not engage properly. The deck ends up resting slightly open. I drive off and get the warning message that the top isn't secure while the operation light continues to flash. Most times, when I get to a traffic light, I can operate the switch again and the deck locks will then engage properly and close the deck all the way. Sometimes, that won't happen and I'll eventually have to use the roof key to lock it properly.Then I have to wait to see if it will go back up again.... mostly, it doesn't, and I'll have to unlock the deck with the key and raise the roof manually... although once I've locked the deck again manually and removed the key I can operate the switch and the final part of the closure will happen automatically. Then I have to wait and see what happens the next time I try to open the roof. I'm wondering if this could be a sensor issue. The hydraulics appear to work fine - except for that final part when the deck is pulled fully closed by the locks. I have taken the motor out and checked the hydraulic fluid and cleaned the brushes but that hasn't made any difference. Any thoughts?
Old Dec 7, 2017 | 06:15 PM
Murph's law's Avatar
I had the same thing happen and I had to take the lock mechanism apart and hit with some lubricant. The center section of the roof, where the tool fits in to manually lock it, on mine was all gummed up. Been a while since I did mine so I can't give specifics. Haven't had a problem with it since. The roof at least.
a3turrell
May 23, 2023 04:47 AM
boomer10
Nov 28, 2011 11:58 PM
s31523
Sep 29, 2010 04:28 PM
AUDI_DAN
Feb 28, 2009 09:23 PM
CWil92
Jul 11, 2005 03:09 PM
