CAR Crash Yesterday!!!!!
Hi all,
SIGH~~~~
I got a car crash yesterday.
the hood, the bumper, and the grille are damaged.
luckily, both the fenders are fine.
how much does it cost to fix my baby?
should I use original parts?
for the grille, I will probably order rs4 grille from ECS.
any suggestions on the hood and the bumper?
THx.
SIGH~~~~
THx.
well,
it probably isn't going to be cheap. you should definitely use original parts. i would recommend looking for a part out or try shokan or force five. for the hood and bumper. I assume you are going to do your own work? It is probably also going to be not cheap to have the "new" parts painted to match. i would recommend taking them to be painted prior to installing.
I'm not very familiar with any aftermarket style options for the hood and bumper but I'm suspect they are out there. They will most likely be more expensive than original parts. also usually require some "tweaking" for proper fitment. And will also have to be painted. unless you are a pro or want your car to look like an abomination, this is probably the more costly option.
good luck
good luck
