to cat, or not to cat
Old Apr 19, 2009 | 03:43 PM
dmfan016's Avatar
Default to cat, or not to cat
my emissions is going to be done this month and afterwards i am thinking about going catless
questions:
has anyone gone catless, what do you like about it; not like about it; performance wise?
is being illegal worth it?
big difference in sound?
have u installed it yourself?
thanks guys!
Old Apr 19, 2009 | 04:10 PM
Mean buzzen half dozen 08 A4's Avatar
I have done this on my Jetta 04 GLI that got totaled.
Spooled up much faster,got a check engine light on afterwards,had to install a spacer that placed the O2 sensor farther out of the airstream in the cat itself,not sure if the A4 will be the same problem.???
The sound,,,,I thought it sounded great!,just a slight low rumble & idle,& not obnoxtiously (SP) loud @ W.O.T. wide open throttle.
You will smell the unburned fuel more.
Not worth the fine if you get caught. Pretty pricey$$$$$
A cat is like having another muffler. So removing it made it sound better,,,,but if you go w/a big exhaust pipe like 3" & a straight through muffler/s out back,,,,it will be loud,IMO,,too loud.
Running two 2.1/4" pipes w/two straight through mufflers & no cat should sound pretty good.
The stock mufflers on my 08 A4,looks to be pretty much straight through ,but has a bend inside,but no baffles that causes the exhaust to change directions.
The APR mufflers are 2 1/4" straight through design from what an APR spokes person told me via Email.
Hope this helps a little.
Sorry different car but basically the same engine.
MBHD
Old Apr 19, 2009 | 05:55 PM
dmfan016's Avatar
fater u had that spacer the cel disapeared?
Old Apr 19, 2009 | 08:17 PM
fater????
The spacer I had is simular to this one: http://forums.vwvortex.com/zerothread?id=4335899
You can disconnect the car battery & it should reset?
At least it did on my VW.
MBHD
Old Apr 19, 2009 | 08:36 PM
dmfan016's Avatar
after*
Old Apr 19, 2009 | 09:14 PM
eMacPaul's Avatar
Some of the chips also have a cat-delete file that will take care of the CEL.
Old Apr 19, 2009 | 11:04 PM
2wdBlazer's Avatar
Buy a catless Downpipe that you can swap the stocker back in at emmission time. Get an APR or REVO tune and you will be automaticly stage 2 with the downpipe and the chip will make your light go away. That simulator / spacer is not gauranteed to work and does not work on some cars.
I have a catless DP on my GTI and APR tune. (HOLY **** is all I can say to that)
Old Apr 20, 2009 | 02:09 PM
dmfan016's Avatar
has anyone installed it on thier b7? i was poking around the engine bay and it doesn;t look like that hard of an install
Old Apr 20, 2009 | 10:22 PM
Here is the cheapest I've seen:
http://cgi.ebay.com/ebaymotors/New-B...Q5fCarQ5fParts
MBHD
