Chip Recommendation
Old Jan 3, 2009 | 10:20 AM
ct brian's Avatar
Default Chip Recommendation
Anyone have a positive experience with using a chip in their audi. I have a 2008 A4. Thanks!
Old Jan 3, 2009 | 12:47 PM
eMacPaul's Avatar
Yep. I've got APR, and it's great! From what I've heard, all the other major brand chips (GIAC, REVO, Unitronics) are also great. APR has the advantage of letting you switch programs with the cruise control. Other than that, just get whichever one has the closest dealer.
Old Jan 3, 2009 | 09:24 PM
ct brian's Avatar
Thanks, I have checked them out. Did you install yourself?
Old Jan 4, 2009 | 02:16 PM
eMacPaul's Avatar
No, you can't install it yourself. The dealer has to connect to an APR server to flash your ECU via OBDII connection. It takes less than 10 minutes.
Old Jan 8, 2009 | 11:51 PM
Quattros's Avatar
i have revo stage 2 and its awesome, never have had a problem.
find out what is your local chip dealer APR, REVO or GIAC, alll essentially the same, go to what is near to you and offers teh best deals.
Old Jan 9, 2009 | 08:21 PM
AWDTURBO's Avatar
I want to get GIAC X Chip. I heard its the most aggressive but it could be a smooth ride when you not pushing the car. Everything i want, speed when i ask and cruising when i don't.
Old Jan 14, 2009 | 10:22 PM
Dunhill's Avatar
I got APR....no problems so far....you can switch from chip mode to stock mode and lock it...
Old Jan 15, 2009 | 04:46 PM
chrisrosin's Avatar
I got the Stage 1 APR flash on Monday and dropped in a K&N air filter. My A4QT feels like a different car. I absolutely love it.
Have you guys that have chipped or flahsed your B7's changed out your DV's yet? I read somewhere here that B5's and B6's should upgrade the cheap, plastic DV after chipping. Is that still the case with B7's?
Old Jan 15, 2009 | 05:23 PM
eMacPaul's Avatar
Some of the later B7's have upgraded DV's. It may still blow out after awhile, though. I've been running chipped for 2500 miles so far, and the stock DV is holding.
Old Jan 15, 2009 | 05:42 PM
chrisrosin's Avatar
Thanks eMac...nice ride, btw. What is a 'VAG to RTW' and Podi boost gauage? Educate the noob :-)
