Chip Recommendation
Old Apr 10, 2009 | 12:39 PM
  #21
REKER's Avatar
So to make sure im understanding correctly, chipping WILL void our warranty?
Old Apr 10, 2009 | 12:58 PM
  #22
prospero's Avatar
http://www.goapr.com/Audi/support/chip_tuning_faqs.html
Will it void my warranty?
Yes and No: according to the Magnuson-Moss Warranty Act:
"No warrantor of a consumer product may condition his written or implied warranty of such product on the consumers using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade or corporate name..." (15 U.S.C. 2302©)
So basically, if you have a warranty claim, the dealer (or warrantor) must prove that the part that you modified directly caused the failure. For example, if you chipped your car and the exhaust falls off, then the car is still under warranty.
Of all of the chips that APR, LLC has sold, as well as pretty much all other chip manufacturers, there just really aren't any problems in chipping the car. Your Audi/VW was so well engineered, that you really are not stressing anything that was not designed to take the changes that a chip produces.
Old Apr 10, 2009 | 12:59 PM
  #23
eMacPaul's Avatar
Any part of your car that would otherwise be covered under warranty that Audi determines was damaged because of aftermarket components will have the warranty voided.
If you get a chip and your door falls off, that will still be covered under warranty.
However, the chips are well tested, and unlikely to cause any problems, so in the event something does happen, it probably wasn't caused by the chip. Audi would probably still blame the chip, but most of the companies have a way to put it back to stock mode so Audi can't tell that there's a chip, and will cover the problem under warranty.
Old Apr 10, 2009 | 01:03 PM
  #24
REKER's Avatar
Great, thanks alot.
That is good peice of mind. I've been thinking about getting the APR chip as my first actual modification.
eelpie
Aug 27, 2014 05:59 PM
mblayton
Feb 1, 2012 10:31 AM
sntemp
Feb 22, 2008 07:23 PM
Bantanic
Apr 14, 2006 07:49 PM
BFlan
Feb 17, 2005 12:47 AM
