The Dillema, 18s or 19s?
Old May 31, 2009 | 10:58 AM
dss1085's Avatar
Default The Dillema, 18s or 19s?
I can't decide which size wheel to get. Can anybody give me some pros and cons of them. I realize that if I get 19s I'll probably have to get some lowering springs for it. Would i need to do that if I got 18s? Would there be a decent sized gap in the wheel well? If I'm going to have to get springs anyways, I might as well get 19s then. Right?
Old May 31, 2009 | 11:19 AM
Kolyan2k's Avatar
I personally think 18s are good enough and cheaper.....but thats just me who is cruising on stock 17s BBS
Old May 31, 2009 | 07:55 PM
eMacPaul's Avatar
Well, you probably want to keep the same overall diameter to keep your speedo/odo accurate. So if you go up to 19s with a 35 aspect ratio instead of the stock 18/40 you can keep the same diameter. I'd lower it, either way. I've got Eibach Pro-Kit springs, and they're the perfect height.
Old Jun 1, 2009 | 05:46 PM
dmfan016's Avatar
you dont need lowering springs... for any wheel size it just makes ur car look bad if u put shoes on it and not lower it tho
don;t get spring kits, get a spring+strut kit because lowering springs put added wear on on ur struts and through time they will crap out on u and the warranty will not cover it. if u have the money get coilovers
imo 19's look the nicest on the a4
Old Jun 4, 2009 | 09:56 PM
2wdBlazer's Avatar
I noticed a ride quality change from 17's to 18's. Im sure 19's will be much worse.
Old Jun 5, 2009 | 10:29 AM
dmfan016's Avatar
absolutely 19 ride is going to be much stiffer you will feel every crack in the road
